Old 11-25-2011, 11:07 PM   #136
rotarykev
rotarykev is on a distinguished road
nice work
rotarykev is offline   Reply With Quote
Old 11-28-2011, 07:07 PM   #137
JustJeff
JustJeff's Avatar
Originally Posted by Pete_89T2 View Post
With that fuse blowing you have a short. Going back to your schematic, I assume that 40A fuse is between the battery + and the fan + terminals as shown. Somewhere, that current flow is being shunted to ground. Is that wire that says "optiional idle up" currently connected to anything? Maybe it's shorting somewhere in the harness? I don't have the FSM handy at the moment, so I don't know what that ECU pin 1O is supposed to be doing.
I worked out the fan issue. It was too small of a fuse I put in there. I had a 30 amp fuse. I put in a 40 amp fuse and haven't had any issues.
Originally Posted by yzf-r1
Old 11-28-2011, 07:08 PM   #138
JustJeff
JustJeff's Avatar
Originally Posted by rotarykev View Post
nice work
Thanks, it'll be nice if I could get the car out of the garage. It idling with an exhaust leak just isn't very rewarding....
I had family in town for the holiday so I haven't done anything with the car.
Old 11-28-2011, 08:05 PM   #139
Good deal, I assumed you had a 40A fuse in there. 30A sounds about right for a fan circuit. Normally you'll want your fuse rated about 10~15% higher than the worst-case current draw your circuit will see in normal operations.
Old 11-29-2011, 12:55 AM   #140
JustJeff
JustJeff's Avatar
I thought I had put a 40 amp in, guess I grabbed the wrong one and hadn't noticed.
Old 12-05-2011, 12:39 AM   #141
JustJeff
JustJeff's Avatar
Took the time to work on my car this weekend. I have a persistent oil leak. It's somewhere around the oil cooler and hoses. It's either residual oil from when I blew an oil cooler hose. I still have oil on the efan blades and who knows how much on the inside of the fan shroud. It could simply be gravitating down.
Or it could be residual oil from the hose giving out and "sponging" out from some foam along the radiator bracket. I've removed the foam so we'll see if that accomplishes anything.
Or it could be a pin hole in one of my used cooler hoses about to give out. But there isn't any signs of oil pooling in any of the foam protecting the hoses. There isn't any sign or trail of oil telling me where the drips on the bottom of the radiator are originating from.
Any suggestions would be grealy appreciated
Old 12-05-2011, 01:18 AM   #142
JustJeff
JustJeff's Avatar
I need advice on vacuum routing. I suspect that I have made a mistake routing my vacuum lines. What I've done is kept my vacuum spider but capped off unused hoses.
I haven't been able to get my electric boost gauge wired correctly. Rather than fighting my subpar wiring I bought a cheap mechanical boost gauge as a temp fix and laid it on the windshield so I can see it's readings. What I found is that I have zero vacuum. I've got my MBC set for zero boost. If I raise my RPMs up to 3k I can see a small nudge in the boost. BUT I never see any vacuum at all.
I took the UIM off to investigate. What I'm wondering is what happens if I put the plastic gasket between the throttle body and UIM on backwards? I believe I put it in correctly, but what if? Also, I find it strange that there isn't any gasket or o-ring to seal this. Should I put a thin coat of RTV on it to help seal?
I have it off now, but I had it mounted with this end toward the TB. The port matches the ports on the TB.
The other end facing the UIM. The ports match the 3 on each side of the UIM.
I had the intakes powdercoated. To make sure none of the vacuum niples got clogged I took a hose and put it on each nipple and blew through it. They were all free and open. BUT I found this when I blew through the middle front nipple.
Oil...so I"m guessing my vacuum routing is wrong. But it also seems like it could have been wrong for some time now. Maybe I'm wrong but should my TB be this coated in oil?
Middle nipple on the UIM corresponds with the middle steel hose on the spider.
That steel hose eventually ends up at the purge control valve
One of the two hoses coming off the purge control valve goes to the middle iron
The other I have feeding back into the spider here
And then comes back to the bottom steel hose and I have that feeding back into the bottom nipple on the UIM
What have I done wrong?
Old 12-05-2011, 05:05 AM   #143
If you're talking about the MIDDLE fitting on the front of the throttle body...
*This is normal.*
That fitting leads to PRE throttle body, so it will never see vacuum.
It will see boost when the turbo kicks in.
You will only see vacuum if you find a fitting POST throttle body.
The fittings either above or below both go to POST throttle body.
Mazda doesn't do this from the factory.
Although there is a *slight* vacuum leak from this area, I think trying to seal everything with a liquid sealer (i.e. silicone RTV) is more headaches that this is worth.
Specifically, you might end up plugging those little holes for the fittings with RTV...
(Don't ask me how I know this...)
If you have this black phenolic spacer on backwards, NONE of the fittings would work.
See above - you did nothing wrong.
That middle fitting is for the emissions system which leads to the purge valve.
It looks like you have everything routed right.
Mazda designed some complicated vacuum control system to suck out vapors from the "crankcase" to be pulled from two different areas of the oil filler pipe depending if the engine was in vacuum or under load with the turbo spooling.
I think it's kinda stupid, but Mazda spent a lot of money figuring all of this out.
As for the gunk on the backside of the throttle plates...
I think yours is a Kouki 13BT?
If so, this is more so...
This is due to reversion of the intake ports.
It's exhaust gases (and other junk) being blown up from the intake ports from inside the engine and emissions.
On Kouki 13BT engines, the secondary ports open up first prior to the primary ports.
This fact allows stuff to blow back up the intact tract and tends to coat the insides of the intake manifolds and backside of the throttle plates.
Again, it's normal.
Old 12-05-2011, 07:23 PM   #144
JustJeff
JustJeff's Avatar
*This is normal.*
Again, it's normal.
I'll have to get more detailed info about how I have my vacuum hoses routed. Tomorrow night if I get out of work with enough time to make progress I'll go work on my car. At that time I'll get more detailed info and pics.
What I remember by memory is this:
Front 3 nipples on the UIM
  1. Top = capped off and not used
  2. Middle = goes to the purge control valve
  3. Bottom = comes from the purge control valve
Rear 3 nipples on the UIM
  1. Top = Boost gauge (right now it's connected directly to the mechanical gauge. Normally I have it routed to the electric sender for the Greddy boost gauge.
  2. Middle = IIRC is the larger and goes to the OMP injectors via the splitter. One of my nipples on that splitter broke. I have it plugged and get vacuum/pressure (not sure which) from a different source on either the UIM or LIM. But only for that one OMP injector.
  3. Bottom = Not sure I'd have to see it to know, it is definitely not capped.
For the OEM BOV and pressure sensor I route that from the nipple on the UIM near the BAC...with a splitter of course.
I'll get more detailed info in the next day or so.
Old 12-05-2011, 07:27 PM   #145
JustJeff
JustJeff's Avatar
Again, it's normal.
I do have Kouki 13BT. But just to be clear Zenki is 86-88, Kouki is 89-91?
Old 12-05-2011, 09:18 PM   #146
Yes, sorry I tend to use the Japan nomenclature more consistently.
"Zenki" = "before" = S4
"Kouki" = "after" = S5
Old 12-06-2011, 08:44 AM   #147
  1. Middle = IIRC is the larger and goes to the OMP injectors via the splitter. One of my nipples on that splitter broke. I have it plugged and get vacuum/pressure (not sure which) from a different source on either the UIM or LIM. But only for that one OMP injector.
On that larger middle nipple, you're correct that it is supposed to go to the 1-4 splitter, and from there to each OMP injector. If memory serves, that nipple is not vacuum, it's just an air bleed (pre-throttle plates). If the splitter is broke, just get yourself 3 "Y" or "T" style vacuum line fittings and use them to make a functional 1-4 splitter, and connect to each OMP injector. If that one OMP injector you have plumbed solo is getting vacuum instead of pre-throttle air, it may not work properly.
Old 12-06-2011, 03:09 PM   #148
JustJeff
JustJeff's Avatar
Good to know. I wondered about that and I've kept an eye on the OMP hoses. I rebuilt them with clear teflon hoses and they all have oil traveling through them. When assembling the engine I thought about getting a splitter like you suggested, but I assumed all the nipples on the intakes saw the same pressure and/or vacuum. Apparently I assumed incorrectly and need to do some more reading about emmissions removal and such.
What the OCD person in me wanted to do was to remove the spiders nest entirely and get some metal hoses to connect what I was keeping. I really didn't like the idea of having to track each hose from it's source and risk mistakes on routing them. I may go back to that idea. Get some metal hoses and bend them to route underneath the UIM and TB.
The top rear nipple on the UIM is what I used to route to my boost gauge. The mechanical sees no vacuum. As a side note this might be related. My brakes have been "mushy" since the rebuild. Before it they were good. I've assumed this whole time that either I didn't get all the air out of the lines or that my master cylinder coincedentally went out. Is it possible that I've got a vacuum/pressure issue that is also causing problems with my brake booster? I have the brake booster routed as it normally is. The metal fitting on the LIM to the metal hose on the firewall.
Old 12-10-2011, 01:39 AM   #149
JustJeff
JustJeff's Avatar
Something I just thought of. I had my secondary fuel rail powder coated...and there is a pulsation dampener in that rail. Should I be replacing that? Are there any rubber or plastic parts in that dampener?
Old 12-10-2011, 04:46 AM   #150
If you're still running the stock Kouki / S5 fuel rails, then the pulsation damper is integrated into the rail.
I don't think you can buy just the PD from the Mazda dealer.
There is a rubber diaphragm inside the PD itself.
