Old 10-12-2009, 05:54 PM   #11
NoDOHC
NoDOHC's Avatar
Wow! 361 WHp is a good number.
I have nothing but respect for you man and you are doing an excellent job.
I am really hoping that you can get the 400WHp, my hat will certainly be off to you if you do (although it already is).
I don't want you to be disappointed on your next dyno pull, so I will throw out some food for thought.
I doubt that you will ever run this close to peak power AFR on the dyno again, I would expect an 11:1 AFR run to give you more like 320 WHp if a 13.0:1 run gives you 360 WHp.
Unless I read the graph incorrectly, your boost was already falling off at this power level (meaning that your turbo is maxed out, or your charge relief valve is failing). I think that bump in the graph was due to the non-linearity of the waste gate completely closing. If you do have the wastegate completely shut on that run, you are going to need a much better flowing set of turbos to make 400 WHp at 11:1 AFR (unless you are running a ridiculously retarded ignition and can pick a lot of power up there).
Still, 361 WHp is not a bad number at all. (That is actually very impressive).
Out of curiosity, did you ever dyno this car NA to see what it would do?
