Old 10-04-2009, 11:20 AM   #13
I made 150% of factory rwhp with 90% of the boost and I'm using more fuel than what would considered safe with the factory injectors. But I'm using less boost so I should need less fuel.... So what's going on here?
Would you run a GT60 at 10psi on your current setup? Its stock boost so you should be safe right? 10lbs on one turbo is not 10lbs on another.
