Old 09-20-2009, 04:57 PM   #11
dudemaaan
dudemaaan's Avatar
Yeah i thought about that. I wasn't sure if the spring pressure would reduce the pressure by the same amount. I haven't mounted the spring valve, when i do i'll probably test the water output. I might have to drill the nozzle out to maintain the same flow, unfortunately the atomization wouldn't be as good. Im on the fense on the advantages and disadvantages of adding the spring valve. I'm thinking a vacuum/boost activated mechanical valve would be even better. If i could find one.
