Old 09-19-2009, 07:43 AM   #10
North west corner is acceptable as well
So, I found the cause of my exhaust leak.... Appears the Pineapple Graphite one doesn't enjoy standing up to a few hours of abuse. Literally burned the graphite up and left nothing but the steel honeycomb. Im going to call Pineapple as this is the second one I've had and while the first wasn't exactely a long life item, it lasted longer than this. In fact this is the third gasket I've been through. If Pineapple doesn't replace this one, which they probably will. I'll be buying a factory one.
Also found the strange noise coming from the clutch.... the T/O bearing fell apart in my hand. I'm actually lucky I made it home. The outter "wrapping" peeled away ..... and scratched of some of the purple anodizing on my clutch cover and when I FINALLY got the trans out (I need a two poster damnit) the thing fell apart sending little stainless ball beaings everywhere.
So now I just need to get the new fuel filter mounted and plumbed, take my 12 speeds and make 6, custom mounting, PRAY the driveshaft fits, and put it all back together by Thursday @ 6 in the morn...... le sigh
