Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotary Diagnostics Systems
Rotary Diagnostics Systems Our Rotary-engine Compression Testers combine off-the-shelf hardware and software to create a reliable system that can be used to obtain accurate engine compression measurements from a rotary engine. www.rotarydiagnostics.com P.O. Box 524 Mont Alto. PA 17222 (717) 352-7096
Old 09-15-2009, 04:49 AM   #4
RotaryDiagnostics
Compression Tester Man
RotaryDiagnostics's Avatar
RotaryDiagnostics is on a distinguished road
Originally Posted by PortedRotorTuner View Post
So how was VIR? I Love that course. It’s one of my favorites!
Yeah, VIR is the best. However, my performance was less than stellar. Had several offs, although minor, and the engine went sour after the first day. The problem turned out to be the little hose that connects the BAC valve to the TID. Took me several weeks of off and on troubleshooting to find the split in the hose that was on the back side of the hose. In the process of troublshooting I disconnected the SAFCII so now I need to get back to PFS for a dyno session. That probably won't happen 'til Spring since I want to get BNR to upgrade my turbo later this year.
Unfortunately, VIR is a bit of a haul for me. It's a 6-hour drive with a few "hills" along the way that test the tow vehicle. It's not too bad going down, but returning on Sunday evening on I-81 is a bear after a day on the track. Will probably limit VIR to one event per year and go with Summit Point otherwise.
RotaryDiagnostics is offline   Reply With Quote
