Old 09-07-2009, 04:29 PM   #4
Jeff20B
Jeff20B's Avatar
'79-'80 manifold. Yes add a piece of aluminum to block the ACV port on your engine. Also add a piece of rubber hose to the nipple on your broken PCV valve and slip a Fram FV266 into it. Then run a piece of 5/16" hose over to the nipple on your oil filler tube in the intermediate plate. Be sure to use zip ties or hose clamps. Or maybe you can come up with another solution.
I added an FV266 on mine and it worked perfectly. It passes the right amount of air to be well within the idle mixture screw limits of several stock carbs I tried.
