Old 07-31-2009, 10:23 PM   #30
I doubt this is the case...
I bet the rotor faces are already black with soot and carbon deposits.
You'd be surprised how well deposits after combustion will stick to surfaces.
Since this is a rebuild, the engine would've been burning inefficiently due to inferior compression from the seals settling in.
This is more than enough time to leave a fine layer of soot on the rotor faces.
Too bad we can't tear the motor down just to confirm this...
Solution: Teflon coated rotors! It's the next big thing!
