Old 07-22-2009, 02:52 PM   #33
mazdamaniac
mazdamaniac's Avatar
mazdamaniac is on a distinguished road
I wanted to bring this topic back up as I believe that my cause to get a new fuel pump/filter was due to pre-mix. I've also talked to one of the GA RX8 owner who tracks and he has stopped using pre-mix on his 8.. Similar reasons to why I stopped..
So, before you start using pre-mix on your Renesis, please think twice!! It costed me close to $500 to replace the pump assembly.
Pre-mix has no appreciable effect on your fuel pump. If anything, it will increase its lifespan.
The problem is the crappy Arram pump unit Mazda used in the fuel pump assembly.
You can read about this here:
http://rotarycarclub.com/rotary_foru...ead.php?t=8540
mazdamaniac is offline   Reply With Quote
