Old 06-16-2009, 12:39 PM   #6
albertomg
Originally Posted by ZachFD View Post
if you jack up the car and grab a rear wheel and try to move it left/right...on a car with really worn bushings it will click left and right a few centimeters.
That example is more useful in determining play in the wheel bearings.
If the rear end steps out on you, and you overcorrect or something and put alot of force one of the rear corners, worn bushing can cause the wheel to toe out and contribute to snapping the car around.
If the rear steps out on your, talent (or luck) is what is going to save you.
Not all the bushings affect toe so your example is a bit presumptuous. Worn bushings will feel sloppy and lack precision which can cause various handling issues depending on which bushing it is.
Understand that I'm not trying to bust your chops. Just trying to broaden your understanding/interpretation. For the OP, he was just taking a long cruise so the effects of driving on worn pillowballs are minimal.
93 Vintage Red R1
Power: Street Ported Motor, 99 Twins, V-mount, DP>SMB cat/MP> RB cat back, PFC, 1300cc secondaries, Fuel Pump, ACT clutch, RB lwfw, etc
Steve Kan tuned - 310rwhp at 10PSI
Suspension: Tripoint custom valved Koni + Ground Control coilovers, Eibach sway bars, SuperPro bushings, Corner Balanced and accurately aligned
Brakes: RacingBrake 4 corner BBK
SSR Integrale 17"x9" +45, Dunlop Star Specs 255/40
