Old 05-26-2009, 10:04 PM   #10
AJ, I would leave the double/spare wire in the harness. Just terminate it inside the harness or even better yet, throw a single pin Weather-Pack terminal on it. This way, if you ever need a low amp ign hot power source to energize a relay, it's already there.
IE: If you ever decide to drop in an electric fan, or fog lights, or anything like that, you have something that can energize a relay when the ign is on and then shut off with the key off.
