Old 05-18-2009, 03:51 PM   #3
Fidelity101
Reliable Source
Fidelity101's Avatar
Originally Posted by Max777 View Post
relocate battery to the storage bins
replace airbox with K&N Cone filter
replace clutch fan with electric unit
remove A/C
Remove P/S (not recommended if you plan to drift)
remove ACV
Remove OMP (only on S4, if it's broken, S5 cars need a ECU chip to remove it)
Remove charcoal Canister
purchase a radiator cooling panel (corksport)
replace the exhaust manifold with a Racing Beat header (performance gain and looks a LOT better)
These things are all unnecesary, but that's a good list. There are complications that arise from some of these "mods" that you need to consider before actually doing them.
woot! I've done all that except the cooling panel and you forgot to add remove the air pump.
and if you wanna get even more nuts go with an electric water pump
My Rx-7 Vids
