Go Back   Rotary Car Club > Tech Discussion > RX-7 3rd Gen Specific (1993-2002) > Archives
Archives Where all the stickies are
Old 03-19-2008, 03:28 PM   #10
Signal 2
Viable Fossil
Signal 2's Avatar
Dan, Please add my thanks for the write-up.
Just to add...as you'd expect, the thrust washer, plate and bearing are also interchangable. In fact the RX8 part numbers NF01-11-D53 (washer); N390-11-D52 (thrust plate) and N3F1-11-D54 (needle bearing) are identical with the exception that the RX7 bearing part number is NF01-11-D54. The only significant difference I could find was price at MAZDAMOTORSPORTS. The RX7 pieces cost about 3 times more. IIRC, ~ $13 vs. $36.00 respectively.
