Old 03-18-2008, 09:37 PM   #2
I8U
KONI Challenge Crew
I8U's Avatar
I8U is on a distinguished road
Honestly, there really isn't a good way to apply those. The decals are a plastic, the heat alone from the brakes will destroy them. Here's the best way to do this...
Prep and paint the caliper whatever contrast color your want, then let that cure, then apply the decals you want and paint the caliper again with a different color and let that dry, then pull off the decals and now you would be good to go. It's like using the decal as a stencil.
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
I8U is offline   Reply With Quote
