Old 04-18-2009, 01:45 PM   #10
Originally Posted by RotaryProphet View Post
Aux outputs and inputs can be had by using the general purpose IO board, but not for spark or injector outputs.
There's also a router board that lets you do sequential fuel/spark control.
Both of the boards are still in beta testing, and both talk to the MS unit via the CAN bus.
Being a programmer myself, I've been working on various stuff of my own. My overall project is a modular ECU, but I've been testing with smaller scale projects. Right now on my desk I have a little computer designed to read two MAP sensors and control four actuator outputs designed to control a sequential turbo setup & electronic wastegate.
I might be in a position to offer aftermarket programmable sequential control soon, but a full ECU is a long way off.
Please keep us posted on this. I don't mind having to write code, but writing machine code is a new territory for me so I may not be in a good position to help in any sorts, but knowing that it is possible to control aux inputs/outputs is good knowledge, as is the ability to do sequential fuel/spark is a big plus to me and may cause me to sway my previous decisions on ecu.
