Old 04-05-2009, 05:12 PM   #12
I rented the autobone puller for $25 and just never gave it back. I had to grind the fingers down slightly though and weld a nut onto the collet though becuase the slide hammers threads were different. Works great though.
I've never had any luck with the grease method.
Of note though, if the bearing is pressed in too far, doesn't matter which tool you use, you won't be able to get it out if you can't grab onto anything
