Old 03-31-2009, 07:18 PM   #15
NOLA RX-7
NOLA RX-7 is on a distinguished road
If you are going emission delete........you basically block EVERYTHING except for a select few.
-Leave the large port on the backside of the TB for the Oil Injector Vacuum spider (unless you are pre-mixing, then cap it)
-Leave the large port for the brake booster
-Leave the port on the turbo side of the UIM (pictured above) for boost reference
-Leave the port for the Fuel Pressure regulator.
Everything else is capped off.
That is really all you should have if you are emission free.
you are talking in the back of manifol between the butterflies and manifol.right can i call you or you call me 239-281-9768 michael
NOLA RX-7 is offline   Reply With Quote
