Old 03-26-2009, 04:23 PM   #3
sen2two
KTEC
sen2two's Avatar
its most likely a vacuum leak. lump idles usually are, but not always. also, when you press your brakes, it takes vacuum to the brake booster. so with already having a vacuum leak, the braking is making it worse.
most likely when you were swapping the tranny, you knocked something loose. dont forget about grounding the tranny also. missing grounds have caused a lot of problems. even when you think you dont need the ground. keep it.
what I have:
What I had:
