| View Poll Results: How Loud am I going to be? | |||
| Cops will pull you over without even seeing you |
2 | 28.57% |
| Cops will have to see you before knowing it's you |
0 | 0% |
| Almost too loud |
1 | 14.29% |
| Just Right |
4 | 57.14% |
| Almost too quite |
0 | 0% |
| No one will hear you coming |
0 | 0% |
| No one will hear you leaving |
0 | 0% |
| Voters: 7. You may not vote on this poll | |||
#9 |
Slow
The baffles will only hurt power. The baffle's purpose is to cut the wave as it leaves the port, but wouldn't the turbine wheel do the same thing? With a turbo in the way, I would assume that the difference between baffles and no baffles would be pretty much unnoticeable. My guess is that if there is a difference, it would be when the wastegate is open as there isn't a turbine wheel in the way.
