Old 02-25-2009, 06:10 PM   #1
nonturdbo
n/a is gay
nonturdbo is on a distinguished road
no fuel need and electrician
ok this is going to be a very complicated thing so just bear with me for a second.
i have an 86 rx7 n/a. right now the fuel pumpis not turning on. the the circuit opening relay is not working. because it is not getting a ground form the brown wire. i jumped it with a ground so that the pump would turn on but the car still does not start. it just floods the engine. now i tested the afm and it seems to be fine from what the shop manual says so now im stuck with a constant ground it floods with it just wired normally it does not even turn on. here is the wire diagrahm for what im talking about
http://www.cochran-racing.com/FSM/s4...NG_DIAGRAM.pdf
the relay im talking about is on page 30 its marked f-08 and the brown wire is not getting a signal what should i check next it is so close to starting and i just want to finally drive it
nonturdbo is offline   Reply With Quote
