Old 02-24-2009, 05:09 PM   #1
87 t-66
87 t-66's Avatar
87 t-66 is on a distinguished road
corksport turboback, fmic kit, BNR turbo, t4 manifold, 550/1680's, stock stuff, more!
As you can see i have a TON of parts i would like to get rid of...Please PM me for fastest response. If you need something that isn't listed let me know, i might have it.
BNR Stage 2 (I believe) S5 turbo -$575 shipped. No shaft play. Polished compressor housing, ported wastegate. Comes with manifold, SS oil feed and return lines (-4AN/-8AN). Also comes with all gaskets, coolant lines, banjo bolts and crush washers. Looking to sell as a package.
Corksport Power Series turboback exhaust - $450 picked up, $500+shipping. Used for ~3000 miles. No rust or damage. Will come with all hardware, gaskets, and hangers. This is the full turbo back exhaust…not the catback. Retails new for $630.
Custom fmic kit - $450. Comes with intake elbow, all couplers, clamps, 2.5” aluminum piping w/ genuine HKS bov.
(2) recently rebuilt 550cc injectors - $75
(2) new marren 1680cc injectors - $150
S5 t2 UIM/LIM/TB/TPS (block off plates included) - $150
unknown SS t4 turbo manifold - $75
s5 alt w/ dual pulley - $75
SS clutch line - $20
T2 clutch slave cylinder - $20
S5 T2 fuel rails w/ new fuel line and fuel filter - $50
t2 throttle cable - $35
oil cooler - $40
hks intake - $40
k&n intake - $40
S5 Turbo TPS w/ connector - $50 shipped
GM Air intake temp sensor w/ NEW connector - $25 shipped
s4 t2 battery/starter harness - $50new fc thermoswitch/coolant sensor w/ plug - $20
jspec top mount - $25
coolant overflow bottle - $10
stock rad hoses - $8
flywheel socket (1" drive) - $10
n319 jspec s4 t2 ecu - $20
variable resistor - $8
radiator brackets (look new) - $25
cold start bottle - $15
charcoal cannister - $10
(2) s5 round injector plugs - $8
PCV (purge control valve) - $7
OMP vacuum spider - $7
s4 t2 n326 atmospheric pressure sensor - $8
s5 fuel pump resistor/relay - $15
s4 t2 fuel pump sending unit - $25
s4 t2 jdm lim - $25
s4 t2 jdm uim - $20
s4 t2 usdm lim - $20
s4 t2 turbo to exhaust mani gasket - $8
s4 t2 jdm bac - $15
strut top covers - $8
s4 t2 cruise control computer - $10
s4 t2 power steering computer - $10
s5 NA engine harness (great shape, missing rats nest plugs, have a spare harness with those connectors that i can include) - $50
s5 TPS - $35
s4 t2 thermostat neck - $15
plastic piece between coolant filler neck and thermostat neck (w/ overflow nipple & cap) - $25
plastic piece between coolant filler neck and thermostat neck (w/o overflow nipple & cap) - $25
long oil cooler line - $15
motor mounts and brackets $40
87 T2
90 T2 'Vert
87 t-66 is offline   Reply With Quote
