Old 02-13-2009, 01:58 PM   #10
Flooder
Flooder's Avatar
Flooder is on a distinguished road
50-60 psi is really low, even for a TII. And you can't compare compression numbers between an NA and a TII. TII's come with lower compression rotors and NA's are higher compression. So if you had an NA and a TII that both got 80psi, the NA is probably a lot weaker than the TII.
So back on topic, the motor probably has lower compression than he's telling you. If the injectors you sent him weren't professionally serviced then they will still probably leak and cause more flooding. The injectors and low compression are what cause flooding.
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
