| Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's |
#11 |
Pricing the all stock coil mount with SS coil bolts and mounting inserts,countersink allen mounting bolts, black oxide ,will be $30 plus shipping ,estimated . The plate for sec gen leading and stock trailing with SS coil mounting bolts and threaded mounting inserts and black oxide countersink allens will be$ 35 plus shipping . The two plates are mounted with the same pattern holes so you can unbolt and upgrade to sec gen coil with ease . The plates are 3/8 thick steel so the threads are strong and will last better than an alum plate .
