Go Back   Rotary Car Club > All thing Racing! > AutoX Nuts!
AutoX Nuts! If you are one, post your set up, questions, etc here!
Old 03-12-2008, 11:46 AM   #2
Willub and Company
Willub and Company's Avatar
Willub and Company is on a distinguished road
good job! glad to see you making the jump on your first event. so things you need/should know/should bring..
1) remove loose junk from the car before you get there. don't wait, do it at your house, only bring loose things that you need, wallet, phone, tools maybe.
2) make sure you have a battery tie-down and that the tray it is tied to is tight, if they sense it to be loose at all, they won't let you race.
3) I highly recommend sunblock. even if you think you won't get burned, you will, always happens. even if it's cloudy out.
4) bring a tire pressure gauge and if possible a small electric compressor. you will want to take out some air for the race and then put it back in after wards. between heats check the tire pressure, it will go up as the tires get warmer.
5) bring lunch, don't expect there to be food there. and don't expect to leave, you will have to work a heat too remember.
6) have fun!
that's all i can think of for now.
Willub and Company is offline   Reply With Quote
