Old 01-17-2009, 11:18 AM   #30
classicauto
crash auto?fix auto
classicauto's Avatar
Originally Posted by RotaryProphet View Post
Has anyone built a turbo renny by just throwing some old 13b turbo rotors & counterweights in? Wouldn't that be easier than sending rotors out to be milled and such, or are the side ports in the ren designed differently enough that it would cause problems with the side/corner seals?
There is an "assist" seal on the RX-8 rotors which is designed to protect the oil control rings from the heat of the exhaust as it wraps around the side of the rotor out the exhaust port......I know there's some people who have boosted the MSP engine in its natural form, but I'm not aware of any cases where they've used the older rotating assembly - and those assist pieces may be some of the reason why not.
