Old 01-04-2009, 07:41 PM   #11
staticpat
Rally Fanboy
staticpat's Avatar
staticpat is on a distinguished road
Worked on cleaning up my wiring and stuff the last couple weeks. I also installed an electric fan. I did a pusher setup since I had lots of space in front of the radiator.
The motor as it sits.
Here's a bad picture of the battery relocation. I ran the (+) to a cutoff switch in the rear. I also put a breaker in the engine bay where the fuse block terminates. Later when I'm sure of the regulations I will add another cutoff switch within arms reach of the driver.
I also got a friend of mine to start making something to fill in the gray. We are going to work on some rotor stencils (speedsource style, but not knockoffs) to fill in the rest. May or may not do a hood graphic.
staticpat is offline   Reply With Quote
