Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > IR Performance
IR Performance www.myspace.com/rotaryexperimentseven (NJ) We work on any rotary cars
Old 11-28-2008, 07:03 PM   #1
IR Performance
IRP Polyurethane Motor Mounts
These will be polyurethane and incorporate the stock aluminum and steel arms (or you can use two of either) They will be the same height as the stock mounts so they won't raise the motor and cause fitment issues like some other mounts. There will be the main mount as well as a smaller disk to be placed under the subframe. There will be a metal insert through the main mount that the bolt will go through. This will not only prevent the bolt from wearing out the hole over time, but will also prevent over-tightening and compression on the mounts. They will be available in at least 2 different levels of firmness. I don't think anyone else on the market offers this. Grade 8 hardware will be used. I can make them in black or the orange shown. Price is yet to be set but will be close with the other mounts on the market. Here is a test fitting picture.
www.irperformance.com
irperformance@live.com
732-662-1794
