Old 11-10-2008, 09:04 PM   #2
have you tried to de-flood it?
Take the fuse closest to the engine out in the underhood fusebox(on the drivers side shock tower)
take out the lower spark plugs.
hold down the gas pedal and clutch pedal, and crank the car over for 10 seconds.
Put the fuse back in.
Put the plugs back in.
make sure the plug wires are properly connected, the one on the front of the coil pack goes to the front lower plug, and the second one goes to the back lower spark plug.
Try that, and the car should start up.
