| 2nd Gen RX-7 Parting Out Parting Out Mazda RX-7 You must have over 4 parts to list your items here. No new parts allowed. |
#27 |
Here is what's left:
I can do Paypal, but buyer will need to add 4% to the total cost to cover fees. Prices listed in RED, and does not include shipping. If you want to buy multiple things, I'm willing to wheel and deal. Located in Cincinnati, OH 45241. Engine Motor is torn down currently. Selling complete shortblock AS IS with following parts (last rebuild)- $1,500 • S5 TII FC3S ShortBlock • Half Bridgeport Irons by BDC Motorsports • Ported Rotor Housings by BDC Motorsports • Atkins 2mm Apex Seals • OEM Mazda 2mm Apex Seal Springs • Mazda OEM “O-ring kit” • New OEM Oil Pump Chain • New OEM Stationary (main) Gear Bearings • New OEM Rotor Bearings • New OEM Side Seals and FD Springs • New OEM Thrust Bearings • New OEM Oil Control Ring Springs Kit • Solid Corner Seals and Competition “Race” Springs • Later/Thicker Cast Dowel Land Rear S5TII Plate • New OEM Front Plate (Thick Dowel Land) • New OEM Dowel Pins • FD Oil Pressure Regulator • Racing Beat Oil Pan Baffle Plate • New Water Pump & OEM T-Stat Misc. Engine • Banzai Racing Oil Pan Brace & Stud Kit - $110 • Powder Coated FD UIM and Polished TB - $375 includes S5 LIM, spacer, and hardware • Custom Port Matched FD UIM to FC LIM Spacer • Mazda Racing Competition Pulley Set - $175 - Has Rare Earth Magnets in Crank Pulley Transmission • ACT StreetLite Flywheel - $210 Cooling • Koyo Aluminum Radiator - $300 • Black Magic Extreme E-fan - $275 • Samco Sport Coolant Hoses - $90 • Yonaka 26x12x3 Core Intercooler $275 • 4” Turbo Intake Pipe - $30 • K&N Cone Filter - $30 - 4" filter • Custom IC Piping - 2.5” Turbo side & 3” Intake side - Powder Coated - $175 Exhaust • Linder Power Systems Custom Divided Manifold (Ceramic Coated) - $800 • Dual SS EGT bungs (1 per Runner) • Linder Power Systems Custom 3" to 3.5” Downpipe (Ceramic Coated) - $300 • Dual Tial 38mm Wastegates - 11.5psi springs - $200 per WG • Custom 3.5” Stainless Steel Single Exit Exhaust - $800 • Borla XR-1 Oval mid-muffler • Magnaflow Race Series rear muffler Turbo • -4AN Stainless Braided Oil Feed -$100 for both feed/drain lines w/ flanges. • -12AN Stainless Braided Oil Drain • Gotham Racing Turbo Blanket - $125 Fuel • 2 x 720cc Siemen Deka Injectors - $120 - Pending Sale • 2 x 1680cc Bosch Injectors - $150 Ignition • BMEP IGN-1A Coils - $320 including custom Magnecor wires • Custom Magnecor R100 10mm Plug Wires • NGK R6725-105’s - $80 Excellent Condition Electronics • Haltech S3 Hall Effect Sensor - $200 includes custom bracket • Custom Hall Effect Sensor Mounting Bracket by Ludwig Motorsports • Optima Red Top Battery - $80 • Greddy Turbo Timer - $90 • Greddy FC RX7 Turbo Timer Harness - $10 Suspension • Energy Suspension Hyper-Flex Full Bushing Set - Black - $100/Brand new, still in Box Brakes • Brembo Blank Rotors – Slotted, Dimpled & Zinc Coated - $200 for front and rear • Hawk HPS Brake Pads - $75 F/R Gauges Complete set - $1,100 • Defi Link Meter 60mm Oil Pressure - $200 • Defi Link Meter 60mm Exhaust Gas Temperature - $200 • Defi Link Meter 52mm Fuel Pressure - $190 • Defi Link Meter 52mm Oil Temperature - $150 • Defi Link Meter 52mm Water Temperature - $150 • Defi Link Meter 80mm Tachometer w/ Link Indicator Light - $150 • Defi Control Unit II - $100 Interior • Corbeau FX1 Pro Seat - $200 • Corbeau Sliding Dual Lock Driver's Side Bracket - $60 • AutoPower 4 point Roll Bar w/ Diagonal Brace & Harness Bar - $400 - Pick up Only • AutoVation Aluminum FC3S Pedals - $75 • Speed Machine Performance Carbon Fiber Dual Gauge Pod - $150 • Tekniq Auto Suede Wheel/Hub/Snap-Lock System - $315 Miscellaneous • Tial 50mm BOV - $200 • Jazz Vented Oil Breather - $60 Exterior • ShineAutoProject Carbon Fiber Sexy Style Vented Hood - $650 • Sparco Polished Aluminum Hood Pins - $35 Brand New - Still in Package |
