Old 10-26-2008, 11:26 PM   #11
Update:
Ok, so today, I replaced the fuel hoses in the back of the car, and noticed that my tank looks really clean! That is great because it means I dont have to take it out and do the whole muratic acid thing with it like I thought I might. I hooked up the last few random nuts and bolts, installed the battery, changed rear differential fluid, and filled oil. The car cranked over really well, even through the battery was a little low on voltage.
I filled the fuel tank, and coolant, put the fuse back in, and tried to start it... no go, but it felt like it was at catching a bit. I dunno why I thought it would help, but I decided to adjust the clutch pedal, and after that, with the clutch all the way to the floor, it STARTED! Holy shit, I was SO exited!!!
The car idled at about 2000 rpm, and seemed to hesitate a bit when I revved it up, but I DID forget to hook up one of the grounds on the engine harness, so maybe that's why?
BTW: Damn, with an open header, a rotary is LOUD!!! I couldn't let the car warm up all the way, because it was like, 9:30 in a residential area, and my mom wanted me to stop making all that racket!
Anyway, I'm gonna hook up a muffer to the header tomorrow, bolt up that gound, and adjust some stuff to make it run better, as well as check the compression just for good measure.
At this point, all I need are brakes, and exhaust, and to weld up the holes in the floor that were left from rust removal...
After that, it's FUN TIME!
