Old 10-25-2008, 10:54 AM   #8
BLKTOPTRVL
BLKTOPTRVL's Avatar
BLKTOPTRVL is on a distinguished road
I obtained a new LIM (thanks Julia)...
When I first pulled the shaft from the 'new' LIM, I noticed for the first time that these actuator shafts are left/right.
So, I got lucky in the fact that the one I obtained had a good left shaft (the reason it was good may be because the c-clip that holds it in place was not installed for some reason).
So, I am now wondering two things:
  1. is it possible that the left shafts are bad on many LIMS?
  2. can a left be converted to a right and vice-versa?
I cannot answer the first question because I have not pulled enough of these to calculate any statistics.
But looking at the shaft, I believe that if needed a left can be made from a right by:
  1. Using a drill press, drill out the pressed indentations - being careful not to drill too deep.
  2. Pull the lower section from the shaft.
  3. Turn the lower section 90 degreese and reinstall it.
  4. Weld (or braise) where the indentations were to secure the lower shaft to the upper.
  5. file to make smooth.
Because I have the shaft I need now, I am not in a hurry to try this, but if anyone is interested in giving it a try - or has an opinion, I would be curious to know if this works.
...shoot a mother-humpin moose, eight days of the week...
BLKTOPTRVL is offline   Reply With Quote
