Old 10-09-2008, 04:14 PM   #5
Intake vacuum leak
TPS bad or out of spec
Dashpot not adjusted properly
Idle not adjusted properly via BAC valve, idle set screw, etc.
Originally Posted by awizzle414 View Post
this is normal, supposed to be for heating up the exaust. Happens when car is in neutral on cold starts. put it in gear on start up and it will idel normal 800-850
Originally Posted by Red Dragon View Post
ok I'll try that
Is your car doing a sustained Rev to 3k? or is it just hitting it then coming back down? Honestly I think your TPS might be out of adjustment as Ted said. The Accelerated Warm-up Procedure should hold the 3K rev for about 10 seconds or so. It doesn't work and needs to be eliminated if possible (or at the very least not allowed to kick on: By starting it in gear as awizzle414 said).
Check your TPS make sure it's reading 1v if you're setting it via voltage test style. I would also highly recommend upgrading your ECU to RTek2.1 and don't look back. But then again it might be more than you want or need... but come on you know you want to. Do it. Come on. It'll be fun.
