Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Design Engineering Works
Design Engineering Works www.designengineeringworks.com (IN) Haltech dealer, custom/performance rotary parts
Old 03-06-2008, 10:41 PM   #7
fikren
fikren's Avatar
fikren is on a distinguished road
Originally Posted by fritts View Post
I am glad someone commented on the cradle mount of the V-mount. I am dead set against hard mounting a radiator, to me its just asking for a failure. Almost any vehicle you find on the road does not hard mount a radiator and there are reasons behind it. We are using a fairly hard foam rubber to cradle the radiator. The top radiator hold downs will actually squeeze the radiator and keep it from moving/vibrating, within reason. We have no plans to support AC based on the complexity and the heat exchanger blocking airflow. The fans that are used are not the stock units. With the stock fans thickness and using a cross-flow radiator did not lend themselves well for the way we mounted the radiator.
Thanks for the comments
So the fans that you are using, will you be offering those with the kit once its completed or more of a "we recomend using X fans with this application"?
Completly understand the A/C deletion. On a note with that though, if you were to use brackets similar to how Chuck did his, I wonder if you could extend the brackets to a stable lenght to where you had a nice gap between the A/C heat exchanger and the radiator. That, theoretically, should give plenty of room for air to hit the radiator without having to go through the A/C, especially with the angle that it looks like your using for the radiator. Only drawback there would be, you would almost have to supply some kind of prefabbed A/C replacement line to make it a kind of do it yourself install kit. Personally for my needs I don't have A/C so it doesn't matter to me at all, just happen to know that alot of people seem to like that frosty cold air in the summers.
Again can't wait to see some finalized pictures seems you guys are heading in a good direction.
Jonathan
93 bb rx7
Destined to be the never ending project car or possible part source for the rotary rat rod
2008 40th Anniversary Edition RX-8 - bankruptcy owned me
RE-Amemiya Super Dolphin Tail Exhaust-for sale
AutoExe Front and Rear Strut Bars-for sale
AutoExe Member Brace Set-for sale
2008 Honda CBR600RR - bankruptcy owned me
Motivation axle/fork/barend/frame sliders
ASV "unbreakable" shorty levers
Tripage Integrated Tailight and Adj FE
Proton Fushmounts
Akrapovic Hex Carbon/TI Slip On
Sato Rearsets
fikren is offline   Reply With Quote
