Old 09-30-2008, 12:00 AM   #2
Brent
Sua Sponte
Brent's Avatar
Supra Pump is made by Nippodenso. If yours says Walbro, I'd say somebody ripped you off. I would contact the seller and inquire.
The hose looks like the coolant hose that connects to the throttle body.
Who knows about the wire. It appears it was spliced in by a previous owner for some reason. Only thing I know to tell you there is look up on the wiring diagram what the wire is suppose to go to based on the pin slot it goes into and go from there if you can't find the other end of the wire floating around on the passenger side floor somewhere.
