Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Re-Speed
Re-Speed www.re-speed.com (GA) Custom rotary parts, specializing in 85-older
Old 09-19-2008, 08:14 AM   #11
Originally Posted by Low Impedance View Post
so i did some number crunching.
i want to use the BBS Vert wheels. Now they are supposedly a 15"x6" with a +38 offset
So that would mean "0" offset would be at a 3" backspace. The difference is then 38mm which divided by 25mm (~1 inch) i would have 1.52 inches.
So that would give me a total of about 4.52 inches of backspacing on a vert wheel
so they "should" work. yay! Now just waiting around for the kit to arrive.
so after checking they are 6.5" wheels so i will rerun some numbers then.
15"x6.5" with a +38 offset.
so "0" offset would be about 3.25" backspace. So in total, 3.25" plus 1.52" inch would give 4.77" backspacing. That is a bit over what will easily fit, so a space will be needed, but not TOO bad of a size. Ill probably run a slightly stretched tire on it with something like a 45 sidewall. Ill see what clears from there.
