I have the same issue with my T2, oil blowing turbocharger and all.
Stock fuel system other than a walbro, gutted cats but stock dual exhaust and a custom 3 inch TID setup. I hit about a 10.6 :1 air/fuel ratio at WOT which makes the car feel like it doesn't have anything to put out. But if I go 1/2 - 3/4 throttle it'll stay between a mid 11 and 12.3 :1 air/fuel ratio and I can feel the power. I'm using an Innovate LM-1 with LC-1 gauge setup and analog out for my ECU to read an O2 signal so it can go into closed loop. Anyway that you can get ahold of a wideband setup? I'm thinking your having the same issue as I am with running too rich of mixture at WOT and it's killing the power. The oil blowing turbo isn't helping either haha.
1988 T2- Breakin complete Boosting 5-7 PSI Currently attending Universal Technical Institute (UTI) of Sacramento, Ca. Classes: Automotive and Toyota/Lexus elective |
