Rep Power: 21 ![]() |
do you have the source to the vacuum spider that pulls vacuum from the injectors, connected to a nipple that seems vacuum? Ie the factory port? Also, i am not sure if the spider is a check valve or not, but you wouldnt want the injectors to see boost pressure.
