#3 | |
rotors excite me
You can warp the irons, and if it gets severe enough you can probably bind seals and or open holes between the compression chambers and the coolant system, both of which can result in severe wear or catastrophic engine failure. Try not to overheat these, it can be evil to them.
Since you overheated it, when you examine your irons and housings make sure you check carefully for overall flatness.
