Old 07-19-2008, 01:56 AM   #1
TheDriver216
TheDriver216's Avatar
My project
Well i guess its my turn to start a build thread.. I will be taking my '82 base model and transform it into something that will make me crap myself every time i drive it.. I just picked up a S5 as a daily so i can finally get this shindig started.
First the machine..
I drove all the way to Greensville SC, to get this since i couldnt find anything around here worth buying.. there is hardly any rust on it.. the gray fender is from someone hitting me in a parking lot so i had to replace it.. It has a cracked dash and alot of sunfade and rubber pars dry rotted and falling apart..
My plans are to rebuild the 12a.. with new rotor housings, seals, bearing etc etc. Balanced rotating assembly. Street port or Bridgeport , turbo II transmission. ford rear end, sump the gas tank for -8 fuel line out to the pump then -6 lines all teh way to the motor and back
The car is gonna be fuel injected with a Megasquirt2 which Low Impedance is assembling for me.. Running Throttle Body Injection on a downdraft manifold.
I will then be adding this
Its a garrett to4s 60-1 .84 exhaust side p trim and clipped , .70 compressor side 4"tapered inlet with a 2.5" discharge
More to come once i start disassembly.
