Old 03-14-2018, 09:58 PM   #4
alavochin
alavochin is on a distinguished road
Did you do any brake bleeding?
If I did some brake bleeding and my ABS failed after.. what could it be?
I was installing an engine brace that required I remove the ABS pump. Reinstalled the pump and bled the brakes. Could not get get a real hard pedal, so it would take a couple brakes pumps for stiff pedal. Since I could not figure it out, I took the car around the block to see how it brakes while driving. ABS light came on. Back in the garage, I realized that my big front brakes had 2 bleed valves and I was only bleeding one of them. Fixed my mistake, rock solid pedal, but now the ABS light will not turn off and ABS system is not functioning.
What do you think happened and how could I fix it?
alavochin is offline   Reply With Quote
rx-7 abs
