Old 01-12-2017, 02:41 PM   #1
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
LEDs in my SA
I've taken the LED plunge and have converted almost all my lights to LED. I'll get
to the almost part later. I first did the console lights, front side markers and the
dome light. The lights I used for the console and front markers were 194 LEDs
in a cool white. For the price you can't beat em. Seems 194s are a fairly standard
light used in a lot of vehicles and, important for LEDs can be mounted 2 ways
in case the LED polarity doesn't see positive/negative on the correct leads.
Apparently these cheap LEDs only allow installation with one polarity.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The front side markers were easy to install and worked after turning them to get
the right polarity. Pics coming in the next post. They are much brighter and seem
to work well in the OEM reflectors. The console I replaced the 4 main illuminatoin
bulbs for the backlighting. I didn't think the blinker/warning lights needed the
extra brightness. I used 6 out of 10 in the package, so I have spares.
The dome light is a regular festoon light which fell apart when I removed it from
the dome. The LED fit right in and was plenty bright.
The SA doesn't have rear side markers like FBs and no hatch light either. Interior
lights done and I like em. The dimmer for the console still works but in a smaller
range because I assume the LED don't come on until a minimal voltage is
reached.
Next I moved to the external lights. I needed 2 1157 brake lights and 4 1156 white lights for the rear lighting. I still haven't dealt with the license plate lights,
that will be a later project. I bought 2 red 1157 bulbs and pack of 1156. The
1156 were polarity sensitive but work fine in the baclup light. The amber rear
trun signals didn't do as well with the white LEDS, I may get some amber 1156
bulbs to see how that goes. I also bought a pack of white 1157s for the front
turn signal/running lights.
These 1157s I returned because they had a polarity issue which is impossible to
deal with on an 1157 bulb. So I could do the front running/turn signals yet. I may
by some 1157 amber and 1156v ambers to see how they work with the amber
front lens and rear amber turn signal.
I bought the wrong electronic flasher for LEDs. Mine is a 3 prong and for some
reason I got a 2 prong. So the signals blink about 2x their normal speed, just like
having light out. Because its an SA, no other unwanted console lights about brakes or turn signals.
Pics coming up next of the markers and rear lights.
