Old 07-27-2016, 06:43 AM   #10
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
The SAs have the tach signal on the leading because the stock ignition disables trailing on
certain conditions. Your car looks fairly stock so I would say it probably works this way.
I bet your alternator is just weak. I've seen the dash lights stay on like that if the voltage
is not good sometimes. Have you checked the battery cables yet? They may be original and
falling apart internally.
You're having fun now! I'm jelly. I'll take a look at my haynes manual to see if it has any
extra words on dealing with the regulator.
