Old 07-11-2008, 03:51 PM   #4
classicauto
crash auto?fix auto
classicauto's Avatar
Kevin,
If you look at their gauge it only goes down to 11... You need at least 10.
FWIW, the actual readout does go down to 10:1, but the LED sweep only shows 11.
That being said I own one and its not very accurate. Matched against the NGK Powerdex AFX (with NTK sensor) the AEM unit will show similar readings only 50% of the time. Rest of the time it will be as much as 2 full points out!!
