Old 05-03-2016, 12:38 PM   #11
Hey Zac, looks great man! Digging it it. I would like to see where you ended up with the timing and I definitely want to know what she ended up making for power on the dyno when all is said and done.
Your Ambient Air Intake system - Love it and especially the use of that profile gauge to get started.... going to need to go buy a bigger one of those. When you're done with the sheet metal work what you can do is take some silicone vac line and slit it open and apply to the surface that's going to be nexto to the paint... protection and all
The only thing that I see may be an issue is going to be the air feed from the brake duct opening. I don't think it will force much if any air from the brake duct to the air filter location. It might even create a small vacuum. I would suggest, as Ted has, to take a peek at Pegasus racing and try to find some ducts that you could split off of to feed both the brakes and the air filter.
I'm doing something very similar with my FC right now. Taking two of their dual outlet ducts and using one to cool the oil coolers, and the other is going to the brakes.
