Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotary Diagnostics Systems
Rotary Diagnostics Systems Our Rotary-engine Compression Testers combine off-the-shelf hardware and software to create a reliable system that can be used to obtain accurate engine compression measurements from a rotary engine. www.rotarydiagnostics.com P.O. Box 524 Mont Alto. PA 17222 (717) 352-7096
Old 10-30-2015, 07:41 AM   #7
RotaryDiagnostics
Compression Tester Man
RotaryDiagnostics's Avatar
RotaryDiagnostics is on a distinguished road
Originally Posted by FC Zach View Post
That and people want to save as much as they can, like here for example. . guy on the RE5 forum made his own.
http://re5rotary.proboards.com/threa...mpression-test
Yes, you can build one of these things yourself, but we offer a complete PNP system along with a detailed user manual and a support mechanism.
FYI-Our first systems back in '06 used the hose in a similar arrangement to the re5 thread. However, we quickly went to our current system when we discovered that the internal volume of the hose affected the accuracy of the results. The duration of the compression pulse of the rotary is so short that the volume of the free space in front of the pressure transducer was not fully pressurized within the hose during the pulse.
RotaryDiagnostics is offline   Reply With Quote
