#106 | ||||
Rep Power: 10 ![]() |
I dunno what you're talking about... changing 8 plugs is a breeze.... turn wheel full right, get 3' extension, swivel, and socket and go to war... easy peasey
![]() Quote:
![]() Quote:
Looks good though! Looks real good... just make sure it's finished before the new year... would hate to have to come out there and kick your ass.... well... Maggie will... missing one year fine... 2... not happening... for your safety... I suggest finishing quickly!
#107 | |||
Professional Stick Poker
Yes, open dumps are out. Only wannabe ricers run an open dump on the street.
![]() Quote:
midget size comparison.jpg The tank I have is in good shape. It was fine for several years in the SA and had premix in it since I got it. A new tank is expensive as shit, but at least they're still available if I have any problems. The SA is going to need a bigger pump anyway and I would rather spend the money for a fuel cell on it as it is more likely to actually need it. Quote:
Tell Maggie to put the knife down.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 Last edited by GySgtFrank; 07-11-2015 at 04:41 PM. |
#108 |
This is what I've been fighting with for the past few days.
Fuel pass through 1 by Kevin Frank, on FlickrI had to weld a few different angles together to make a pass through in my fuel tank enclosure for the stock fuel filler. The vent pass through only required a straight piece, so that one was easy. The fuel filler involved a bunch of different angles, so it was a bit more of a pain to do. I'll get paint on the enclosure (some of it will be impossible to get paint on once it is in) and get it welded in position, pictures of that will be forthcoming.
#109 | |
sweet
#110 |
... and the fuel tank enclosure in paint.
fuel tank enclosure 1 by Kevin Frank, on Flickr fuel tank enclosure 2 by Kevin Frank, on FlickrThe muffler enclosure, which fits behind this piece, will have to be done in the car. The entire tank and muffler piece will not fit in the trunk opening so it needs to be done in two pieces.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 Last edited by GySgtFrank; 07-20-2015 at 06:09 PM. |
#111 | |
You might want to use a beefier lift next time...
looks good!
#112 | |
#113 |
counting down till DGRR
I'd rather see you working on the first gen
![]() Good work anyways
-74 RX-4 -84 REW GSL-SE Past rides -05 REW Swapped RX-8 -93 FD base |
#114 |
Actually so would I, but the little green monster had other ideas. I'm planning to go turbo with the SA so most of these parts need a new home anyway. That is going to require a re-think on some of the stuff on the SA, so probably just as well.
#115 |
Best laid plans of mice and men. Or something like that.
![]() We all have our hanger queens. Sometimes they just require longer stays in said hanger. |
#116 |
True, but having a hangar queen because you choose for it to be one is far more enjoyable than when the car chooses it for you.
#117 | |
Youll have plenty of tire for it.
#118 |
I want to go RE or REW, based upon the way MC and Brian built his engine. The power levels and torque would be perfect for what I was looking for. It could be a long project though, as just getting all the parts together to do it will be expensive.
#119 |
Or you could try to find a big enough tire iron to take the keys from MC.
#120 | |
