Old 06-21-2015, 09:09 AM   #11
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
No, I didn't bother to bake it. Once it gets fired up it'll get "baked" on. I used the same paint on a previous header I had sand blasted, then painted. Worked well. Not as tough as Ceramic coatings in that it will chip more easily if you drop stuff on it, but a lot cheaper and easier to touch up when you have to. Mainly I just want to keep them from rusting.
If anyone is looking for a show quality build, then my builds aren't it. They will have to look elsewhere for that kind of eye candy. I just want the damn thing to work, and work well. The information I present is for others to see what my solutions were to the build so they can plan accordingly if they choose to try something similar.
A picture of the other header, it didn't discolor and held up under use, admittedly not a lot of miles, but it didn't burn off with the four cylinder. How well that holds true for a rotary we'll have to see.
GySgtFrank is offline
