#11 |
Don Mega
M&W (COI-006) drawn up, looks like will not go vertical without some thought (gotta flip shit around) will
it in there ![]() New headaches start!!!! ![]() 4.46mm back from the front rotor housing edge (not as good as the IGN-1A can use 4 holes to bolt down. Still needs odd mounts due to offset on flanges, cant have coils lined up as wiring harness plugs smash into spark plugs sadly. This is only way to fit it vertical, otherwise will work on horizontal version ![]() ![]() ![]() ![]() ![]() Coil needs to be spaced out to achieve a horizontal fit, kinda defeating the benefits of the female coil end...... ![]() Only way I know how to fix this is to trim back the connector interface on the coil, potting it and fitting an autosport connector or DT series (similar to my original COP on first page) more remote style quick disconnecting position. This would free up some room, but not make it true 'plug n play'. Leave it with you all to mull over, if it was my own set up, then I would molest the coils fuck off the connector and trim it right back and gain 15mm space, and run the remote connector interface horizontal will need lots of mods to make it work/fit. molested coil below, needs connector trimmed, holes drilled in it, 3 wires inserted and fixed, pot the other side of the connector end, heat shrink and another connector, up in the bay where you can get to it, as on the front is a c-u-n-t. ![]()
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-13-2015 at 05:18 AM. |
