#271 |
Don Mega
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 12-03-2014 at 05:01 AM. |
#272 |
Get off my lawn!!!
Rep Power: 15 ![]() |
You must love your seafood mate.. Those scallops
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
#273 |
Rotary Masochist
_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
#274 |
Rep Power: 20 ![]() |
^Damn those look good haha. Sucks being deployed and getting shit food lol.
Those rotors look delicious also. I forget, are the scallops just for weight savings or do they benefit rotation in some other way? Also, the attachment on the side of the housing by the spark plug holes...is that to flow more coolant where it's hotter and those are banjo bolts? That's pretty trick. How does it attach at the blue fitting? Is that a banjo bolt also? |
#275 |
Get off my lawn!!!
I believe scalloping the rotors like that is done to extend how long the intake is open for.
#276 |
Rotary Masochist
More duration without overlap.
#277 | |
Don Mega
* primary reason is to reduce the compression ratio to allow highest power with reliable operation on any basic petrol * gives overlap earliest possible opening and latest closing on RICE RACING street port, also improves 'flow' * CR benefits listed below ![]() On the plug cooling: Its banjo style into rotor housing, and AN fitting inlet, in pic is just a block off cap.
#278 |
Don Mega
As stated its mostly done to allow the correct engine compression ratio #1
On the overlap aspect: My engines actually have quite allot, not as much as a bridge or semi pp, but enough (maximum possible on a street port) to allow high Ve at high rpm thereby improving power output and rev range. Its the best balance for an engine running on the street yields highest average power curve when matched correctly in other areas. You can tell this when you look at equalized engines such as in my power at 1 bar NA thread. I have a very extensive list on this (far bigger than what I put in that thread), This combo pictured with an EFR9180H and Cosmo inlet manifold on RICE RACING street port is well over 260bhp @ 1 bar (N/A) and it works to 4 bar reliably.... which is a little bit of power
#279 | ||
Half bubble off plumb
Rep Power: 17 ![]() |
That scalloped rotor is the TITS!!!
On another note, Peter, it made my day to see the banana from the rejected cartoons at the top of your webpage... I laughed for a good bit about that... J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis |
#280 |
Rotary Masochist
I didn't take into account scallops on the leading edge of the rotors. I've only ever used them on the trailing edge. So, yes, you will create overlap. Good looking work!
#281 | |
Don Mega
I will also have up pics of my own manufactured Apex Seals soon too
#282 | ||
Did you modify the size/shape of the tub on the rotor to lower compression? Looks like you increased the area and depth of it...
J.
#283 |
Don Mega
YES, it is the only way to cure the FUCKED Mazda casting and equalize the CR on each face, but most importantly to run the correct CR needed for highest power and reliable operation.
#284 | |
Don Mega
If you look at the old Honda F1 turbo days (running 84% Methyl benzene fuel) 2.5bar (22psi engine) ran 9.5:1 CR 4.0bar (43psi engine) ran 7.4:1 CR It's all about using the right CR to stay within the effective compression ratio guidelines I posted above in my spreadsheet. early pump fuel turbo engines ran 6.5:1 CR Mazda Factory 13B bridge turbo's and the same motors sent to RB ran 7.5:1 CR Its not Rocket Science, just basic Thermodynamics and laws being respected. My CR is not openly disclosed but you can guess it's near these correct figures
#285 |
OK thanks!
