Old 06-01-2014, 07:21 PM   #5
RICE RACING
Don Mega
RICE RACING's Avatar
Originally Posted by Mitchocalypse View Post
The only problem i'm having it that it won't rev past 2k rpm. Both rotors are firing and seems to be working fine.. until 2k.
For the amount of effort it takes to hook up a pfc just to see what happens, i don't think its a waste of time.
At idle the AFR is right around 11 +/- a little bit. Looking at the tune, that is right where the target AFR is in those cells so i really don't know what to make of everything.
It sounds like your trigger signal is dropping out as the thresholds are optimized for the stock set up, hard to diagnose from here.
I will do up a file on the PFC for 3.5 bar sensor and ID1000 primary so you can test it, will send through tonight my time. I have a fully done and verified map for 550cc and 2200cc set up (which works perfectly on PFC platform), but to save you changing injectors I'll just molest some figures so you can run a test to validate your theory.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
